Diggity
Joe, that video of Daniel hammering the crap out of the 91" extra looks insane.
I wonder if he used a 24x10 size or proped up with the bigger motor?
I read somewhere he is using a 24x10 because he is still breaking it in.
First off - if you have play in the control surfaces you have a problem. Either worn servo gears, bad servos, loose screws in your linkages, something. That's purely a setup problem and will definitely make the plane fly worse.I finally maidened my MXS this evening, IN THE RAIN. wasn't none too pleased with the way it handled. Im hope'n that it was the servos. as far as just flying around it was OK. but harrier was a freakin hand full, as was landing and im pretty spot on when it comes to landing. to keep a straight harrier I had to give around 3/4 left stick, my other planes jump a bump of right stick. even at that it was very squirrely, unstable and unpredictable. I was flying nose heavy as I do on all maidens and first 15 flights or so. there is some play on the control surfaces when I try to move them by hand. elevator at center had no play but toward end of throws each way there was quite abit of play. ailerons seem to have alil at center. im gonna get some new servos and try them out. I really hope that's the problem.
the only other 3d I really tried was to hover and a few rollers. hover was pretty easy but I didn't have to be on the sticks all that much. rollers pretty much sucked but I usually have to get used to and really dial in the plane before mine look decent on those. did try a couple elevators but even with extreme throws they didn't drop too much like they should have. idk just hope'n its the servos. kinda sucks, wish my noobular self had somebody I could go to
Here you go:
what i was kinda thinking about the thrust because that is pushing it back to the left alil . but i do wanna try and fix it and worse case correct it.The servo problem isn't going to be the reason behind the 3/4 left stick. That gap will throw off your thrust but it appears that it would need right rudder, however if you trim at 3/4 throttle it may negate that effect at lower throttle settings. If you can't get that gab back in and glued, you should be able to offset with some washers. There is a check sheet I will try to round up and post.
Here you go:
