Liberty10;18575 wrote: I have the DA35. I took IR gun readings that all looked normal the first week. Now I have a sensor for realtime temps. I placed the sensor in the second from the top fin space and it is on the back side of the cylinder. Temps the first time were 295° peak. It worried me a bit but the IR gun temps still read normal on the ground. Anyway in much cooler temps on Saturday (70°F) the temp peaked at 260°F. I'm planning to add a baffle that will put air thru the fins from on side to the other. We'll see if this lowers the rear head temp or not.
do not be worried by that "true" temp. what i mean is, that traditional thought on using IR guns and measuring temps on front of cylinder, in my opinion is erroneous. SO, the "standard" values are an underestimate of real world temperatures.
at what temps should we get worried?
this is the million dollar question....
i can tell you this, and i do not suggest you do this,
but i was running my DA 70 with good baffles ( i thought) and on a day with ambient temps in 95, the sensor in back of cylinder, as close to spark plug as possible, during flight, temps got up to 400 F, and once it got to 450 F, the engine began to fade.
this tells me, 400 F, it was doing fine, 450 F is too hot!!!
with that said, if your temp on the front of cylinder ever got to 400F, that means that temp in back of cylinder is even hotter, and i mean, by 80 to 120 degrees hotter (ouch), you are looking at seizure time.
in any event, i then re did the baffles, i opened the bottom of the tunnel for the pipe, which i do not have, and i placed a air dam in front of one of the openings, and now, temps are in 280 to 300 range!!!
it is critical to have at least 3 to 1 on the area of air exit relative to inlet area.
and then, creating some form of air dam, that will help create an area of negative pressure, and thus extract the hot air out!! this will dramatically help in cooling your motor and preventing motor performance fading, oil breakdown and lack of lubrication, excessive carbon buildup, and potential seizure.
the cooler you keep that engine temps at, probably the longer it will last.
your peak temp of 295 in the back of the cylinder is not worrisome at all.
but do try to make baffles and help the hot air get out, and i bet your temps will drop to 260 max as peaks.
i have a DA 35, and these are my temps on it:
6/1/14
Engine: DA 35 cc with pitts muffler
Fuel / oil mix: 40 to 1 redline, 91 octane
altitude: 200 feet
ambient temperature: 87 F
prop size: 20 x 8 Xoar wood
air frame: 78" extreme flight extra 300
radio system: Jeti
data:
1. highest cylinder head temp during flight (not after landing): 357.9
2. temp range 309 - 357.9 F
3. temp on landing and taxing back = 280 F
