Scale F7F Tigercat 1/4 scale
Thanks for that. Went to the site not much there and the video was not in English. But I got the just of it. Did figure out is that they sell three models 10kg , 20kg and 50 kg. Is the resolution on all three units the same. For the 20 kg would be good enough for me do not think I would need more than 44 lbs. or am I missing something.
Have a bunch of questions is that ok especially around the connections and interface with my I-pad will that be ok.
For the difference in money, I would go with the 50 kg, then you are safe . just my opinion.
Of course ask away, and if I can't answer, Milan (owner) will give answers,
As for the connections , it is with wifi only, with this said , when the main unit with the power supply used, the green led will light up, at this point with your tablet, or laptop, on, go to your different wifi detected , you will A.M.E. connect to this , then in the google search , type 2.0.0.1 click search, and voila, you have what you need,
tomorow someone is coming over for me to balance his aircraft, and at that point I will take pictures of what I just described to you probably a short video as well
Thanks i will appreciate that the connection to the IPad is still a little vague. I know what I am reading but just not understanding. Does the unit send out it’s own Wifi, that the iPad can receive.
yes exactly the unit does send its own wifi , Hopefully the video I will do tomorow will explain it better, but you will see its quite simple once you know it
I twisted my brains at first , then it simply dawned on me.
plug the unit using a cell phone charger , making sure it is not over voltage
check for availlable wifi network , you should see A.M.E. as you see here click on this one to open
click google search, and enter 2.0.0.1 as you see up in the photo,
this will open immediately
You can do the same for your cell phone or laptop
Update::: I am back on the tiger cat, here is what happened, first the first part of the folding wing part were not up to snuff, I made some mistakes and decided to start over, so far going well, but the other reason it was on hold, is my investing partner also wants to do the Boeing XF8B from 1944 , so we started to calculate which engines would ready first, the R18 or the R28, so with the R18 are the front runners , then we go forward with the F7F and this is when I say , "Are we having fun yet"
