Red Raider
OUCH!!!I have had s hall sensor go bad and cause the same thing. Got popped by a 29" Falcon!
Of course when it hit my hand, it slung blood to the top of the awning, and made a small splatter spot on the ground. It must be God's way of taking care of idiot modelers, but my finger instantly went numb. When I got home, I cleaned it real good with hydrogen peroxide, and then went out to the shop and put a couple of drops of CA on it to close it up. Did you know that when the CA goes off, it gets really hot!!! I think God was laughing at me.
Thanks, Dan!An over rich mixture at engine start can cause the problem you're having. An engine near flooded will do just as you describe. I had this problem with my first 3W-106. I leaned the carb just slightly, and learned to flip the prop with "authority". I called Gerhard about this issue, he said "flip it like you mean it" or something to that effect. (Can't remember his exact words).
You're welcome!Thanks, Dan!
I think that's the explanation I've been looking for. I'm notorious for running my engines on the rich side. I do that during break-in, and then never adjust them properly. Hey, if it's working, don't mess with it right?!?! Wrong. Sometimes "working" is relative. and in this case, dangerous. or least painful.
Yep. waterproof and airtight. Those are the main things that make a cut painful. Mine is healing up nicely. My wife thinks I'm crazy and that I am likely poisoning myself. I tried to explain to her where it was developed and first used. She isn't buying it. Have you ever sprayed it with accelerator when it was being a little slow to set?? Now that's a blessing!!!!! YIKES!!!CA glue was used in the Vietnam War to heal our wounded warrior...
I have used CA many time to close up a wound...burns like hell but does the job...no need for stitches
actually I have, Holy hell did that get exciting....and It was caused by a prop strike....APC prop on a nitro plane adjusting the needle before flight...sliced me open good....Yep. waterproof and airtight. Those are the main things that make a cut painful. Mine is healing up nicely. My wife thinks I'm crazy and that I am likely poisoning myself. I tried to explain to her where it was developed and first used. She isn't buying it. Have you ever sprayed it with accelerator when it was being a little slow to set?? Now that's a blessing!!!!! YIKES!!!
could not get it to stop bleeding with just instant CA....so took some medium with kicker and that did the job...but it did burn a bit..lol
