bobzilla
Giant Scale Setup Powerbox 40/24/Ignition regulator/Switch/Batteries
Complete giant scale setup for 30% and up. Items were installed in 46% Ultimate, but never flown.
Includes the following:
Powerbox Competition w/sensor switch - $180
includes PowerSystems Powerbox Competition 40/24
and a Powerbox Systems Sensor Switch, 2 fault LEDs, MPX to XT60 adapters.
Powerbox batteries - $45[
includes (2) 5000mah (2s) 20-30amp LIPO (new) w/adapters.
SOLD SOLD Two (2) JR Matchboxes - $75
http://www.horizonhobby.com/products/matchbox-servo-matching-power-system-JRPA900
One (1) Smart-fly ignition regulator (5.5v), with switch/charge jack and one (1) ThunderPower 2700mah (2s) 25 amp LIPO with adapter. - $60
Paypal OK
Sorry, no trades
Powebox Competition 40/24
Specifications:
Double linear voltage stabilisation for receiver and servos, supplying 5.90 Volts
Power handling up to 2 x 20 Amps
For 7.4 Volt LiPo batteries (PowerBox Battery) or 5 NC or NiMH cells
7 channels remotely accessed from the receiver
7 two-way signal amplifiers
24 servo sockets on the backer
Interference suppression for all 24 servo inputs (no ferrite rings required)
Independent, IC-controlled voltage monitors (LED chains)
Two external ultra-bright warning LEDs
Minimum voltage memory (low voltage memory) for both batteries, can be read individually
Two integral electronic switches, controlled by the SensorSwitch
Operating voltage range 4.0 to 9.0 Volts
Temperature range -10° to 55° C
Voltage loss approx. 0.35 Volts
Current drain 25 mA
Weight only 148 grams complete with all cables and SensorSwitch
Paypal OK
Sorry, no trades
Specifications:
Current drain 25 mA
