FlyingAddict
I started my new GP123 today. Started the needles per the manual H: 1 1/2 L: 1 3/4. Engine started with no issues. Set the high needle for max rpm at full throttle, turned the needle maybe an 1/8th clockwise. From a high idle, @2400 rpm transition is good. If I have the idle @ 1700-1800 rpm the engine dies as soon as I rapidly increase the throttle to full stick. Tried turning the low needle counter clockwise to richen it. At incrememnts of about 1/16th of a turn at a time i saw no improvement. I made it out to 2 3/4 and then the motor would not restart. Set back to 1/3/4 and started to slowly lean the engine but it would still die when I tried to transition.
