did you cut the end of the spring on that arm?
I did not. The only thing I did was remove the idle set screw/spring.
ok, thanks Gary
Looks like mine needs to go to Kole. Muffler will not stay attached to the engine. Beyond frustrated right now.
It came loose on the second flight of the day yesterday, and then [MENTION=271]Enterprise[/MENTION] spent a ton of time putting the high temp RTV gasket maker on redoing everything. Let it sit for 24 hours, then first flight of the day after 2 minutes, rattle rattle rattle.
Heads up [MENTION=2452]Limitless Aero[/MENTION], you got an engine on the way
Get some nord locks
I was wrenching up the muffler after every 4th flight...Almost to the point where I was going to put some holes in the cowl to make it easy. Then go some Nord locks....Never had a problem since.
This is the part number I ordered.
91812A227 from McMaster Carr
