Griffwerks MX
FlyMike1
This flight here was with 2s batt and windy. Its about half the power i get with 3s But I can still fly the plane
[video=youtube;vCXpOVzJIY4]https://www.youtube.com/watch?v=vCXpOVzJIY4[/video]
3dNater
Ok so you could get more power on 2s by putting a larger prop on if your esc/ batteries can handle the extra few amps.
FlyMike1
Looks like the indoor he sells has the same ESC as the out door but different KV motor but both lists 3s batteries. Different props also. I dont change my prop when switching between 2s and 3s so I cant tell you.
Here is a video of how tuff the plane is. This was 3s and you can tell between the videos how much more power there is...[video=youtube;9eBuKZhT6W4]https://www.youtube.com/watch?v=9eBuKZhT6W4[/video]
JTI
Flew several times and I doesn't seem to have enough power. I got the 1500 and outside moved up to 3S then also tried 8 inch 4.3 prop.
That seemed better.
Still not half as fun to fly as my Crack Laser. A light wind has way to much effect on it.
Can someone recommend a hotter setup that I can put on it? I have a Park 300 that I might try if I can mount it.
JTI
The park still not enough and just got hot.
Found the left aileron coking off. Fixed but the ESC is fried.
Flying my new 39" crack yak 55 from TWISTED HOBBIES:D
