I've only built one gas plane so far, but another factor may be servo arm length. I built my 91" Extra per the manual, but experienced some aileron flutter using ridiculously strong MP82T (current model is JR MP82T MKII) JR servos powered by 2S, sealed aileron hinges, and no side force generators. These servos are 563.8 oz/in @ 7.4V according to manufacturing specs.
The lingages are all very tight tight. Horizon is currently looking at the servos, and initial indications are they are good--but one other issue might be the servo arm length I used. I used 2" per the manual, but the new recommendation is 1.75" now from what Chris told me.
This 91" Extra has large control surfaces for a 50-70cc sized plane from what I understand.
Anyway, my next plane is a 105" Pau Extra with a DA120, and I'm still trying to figure out how I am going to do the two servos per wing. I think I am going to run both servos per wing to the ailerons, and use a current meter and servo/radio programming to minimize how much they fight each other.
I'm guessing that this will be a several hour process, especially if I get programmable servos, because there are so many trade offs and I recalculate things a million times it seems, and mechanical engineering and thinking in 3D is not my cup of tea.
