This is a really great chart. If only someone would come up with a motor mounting chart, that would be awesome. DA 150, 170 and DLE 170 are the same...this I know. Different from 3W157 and 170.Super08;16561 wrote: According to this they are the same.
stangflyer;17015 wrote: This is a really great chart. If only someone would come up with a motor mounting chart, that would be awesome. DA 150, 170 and DLE 170 are the same...this I know. Different from 3W157 and 170.
Cool...this is good info to have. I did find out that the DLE 170 is also 80mm x 90mm on the mounting plate. 3W157 and 170 the same, but different than DA and DLE. I've been so anal about whittling and carving away at my servo bays on the new Sukhoi to accommodate other servo applications, so I went with Hitec HS 7950TH on all surfaces. (drop in fit) Now after looking at the firewall that is pre-set for DA 150, I'm now leaning to the DLE 170 as it will be an exact bolt on.orthobird;17641 wrote: da 200, 170, & 150 have same mounting bolt distance. = 80 mm by 90 mm.
the prop bolts on a 200 are same as a 150. the 170 is also, except it takes 6 mm bolts instead of 5 mm bolts. the 200 and 150 both use 5 mm bolts on the prop hub.
this is all i know, from experience with these 3 motors. I have x2 170, X 2 150L, and X1 200 ( i also have DA 35, 50, 60 (x2), 70 twin, and a DA 120)!!!
orthobird;17921 wrote: Just flew her, brand new DA 150L. turning a Mejzlik 30 x 12 LF. please look at video and tell me what you think about the sound and running of the engine.
https://www.youtube.com/watch?v=60iCwLeuX_E&list=UUZYrMHmbHD9fMkFu1exq6Cw
