RC Parts For Less
30cc
Hey Guys,
I am at my wits end. I am very familiar with DA and DLE motors but I only have a couple 3w motors. I purchased a 546 for a project I’m working on, it was used because the budget didn’t allow for a new motor. I bought this motor trusting the person selling it which I have found was a huge mistake. The carbs that came on it didn’t fit and were not the carbs meant for the motor. The ignitions also were not the proper ignitions for the motor. I have purchased a new intake as well as one carb to mimic the motors. I also bought the correct ignitions for the motor. So after all that now to the issues. I have mounted the intake and carb, that’s all good, I assume, won’t know for sure until I get it started. I also put the new ignitions on , this has a two magnet set up. The information that came with the ignitions is vague at best. The hall sensors are the ones that came with the motor, the ignitions have spark so I know they work. I have tried starting the motor but have not had any luck.
My issue is I am not sure if the motor is timed correctly. To make matters worse there are 4 magnets on the hub, not sure why. Anyway, it looks like the magnets are somewhere around 40 degrees after TDC as seen in the instructions. I cannot get the motor to pop or show any signs of life at all. If there is anyone out there that has some documentation for timing a 3w motor PLEASE, help a fellow rc’er out. I want so bad to hear this monster roar to life. I need to understand the timing and what to put where. I will send or post any pictures you guys need I am desperate here so if you might know what I should do please let me know.
