dth7
What exactly do you guys mean when you say fine tuning and tinkering on setting up different rates and expo? I have triple rates, actually with the dx9 I have capabilities to setup more. Reason I ask is to see if there is more I should be doing or to see if I'm setting mine up right.
Great question and sorry we weren't more clear. Basically what you want to set up (and it depends on your flying style, plane, Tx and feel so I can't give you specific numbers) is that you are not over controlling and working too hard to maneuver the plane. So start with the basic setup (which done correctly is a long process)- Mechanical linkages, CG, thrust line aileron differential (axial rolls), trim, etc. When you are happy with that move to your rates and expo. As discussed above you don't want anymore throw than you need for the most demanding maneuver in your flight (that's the nice thing about multiple switch settings). The other thing you might look at is stick deflection for different maneuvers so they can be repeated accurately. If at 1/2 throttle a full stick deflection gives you a clean crisp snap roll it is more repeatable than a mid stick deflection. Obviously this changes with speed and power but better to start with a known. Does that make sense and help a little?
Like anything else with this hobby tweaking and more tweaking. In the end it makes the flying more precise and easier.
This is an expansion on the argument many of us have had with CFs about flying without expo vs with it. The more you can do to make it more precise and easier why not? (shy of gyros- an entire thread on its own, let's not go there). For instance on my 78 extra my throws on low setting run in the 20-30% of high rates with corresponding expo. I like my expo set so rate changes don't cause much if any control change. iMac- low, Acro mid (may be switching One, two or all controls, XA/, 3D- high (again may be high elev mid aileron depending in maneuvering). My rudder generally stays on high.
I hope that helps. Thanks for asking the questions. Sometimes the questions not asked are the worst ones!
***note***
In the IMAC Pro app there is a wonderful "Tip" link with a very thorough explanation and even charts and checklists for setup. There is an order that should be followed and Peter Goldsmith brings you through it step by step. Another great reason to use this app.
There are judging tips as well. Look at the freestyle judging sheets and explanations and you'll see where we are getting our motivation for XA flying. Just add "...the flight envelope and beyond"
