Welton1720
Delete post
another question for you all!!
this is in regards to the Sportsman sequence. the known,.
question.
when you fly inverted, do you want the airplane to maintain level, or do you guys like to push to maintain level.
- Most pilots, for precision flight, want the cg slightly forward of neutral. This results in the need for a little bit of negative pressure while inverted. A plane that is balanced at neutral becomes extremely pitch sensitive and as result tends to exhibit rather poor tracking characteristics, among other issues.
ok, question number 2??
i have noticed, when doing two of 4 point rolls, that when i am going down at 45 degrees, the first 1/4 roll, in order to maintain a line, immediately after rolling it there, i must apply some rudder correction. Would this be normal and expected?
ok, in addition, i have discovered the same with the 2 of 4 point rolls on a 45 degree climb.
- Yes. Anytime the plane is rolling, the primary lifting surface is changing from the wings to the fuselage and back to the wings. In very simplified terms, when in a knife edge attitude - even if only briefly - the fuselage side becomes the primary lifting surface and needs to be placed at a positive angle of attack to maintain level flight. In other words, the tail needs to go down, the nose up, the rudder input is commonly referred to as "top rudder" - rudder needs to go up to make the tail go down.
