Question; I have split ailerons on all of my planes. On the 42% planes the ailerons are split into three sections.
I use the two outboard sections to fly most of the time. I have the aileron option of using
all Three Sections or just the Two Outboard Sections can be selected on a two position switch.
When I am in the Two Outboard Section mode (condition), I can use the Inboard Sections as Flaps. The Flaps are employed using a Slider Switch. The degree of Flaps Down is set with a Dial and there is a Down Flap to Elevator Mix to set up level flight when the Flaps are down.
How would you set this up on the Jeti?
