Hey everyone, I am very unfamiliar with the JR radio systems as this will be my first JR setup ever. The menu and commands in the transmitter are a little confusing compared to my Hitec Aurora 9x, but I am sure I will figure it all out. Probably for most or any of you JR owners, it is actually quite easy. Offer some advise or input anytime you like. I could use it.
My questions at this time however pertains to the RG1131B receiver. The satellite attached to the receiver is an antenna/telemetry satellite as I understand it. I really do not know much about it or the system so please help if you can.
Questions:
1) Where is the best placement for the satellite? Away from the main dual boda antennas?
2) Is it possible or is it suggested to get a longer extension for the satellite? What length would be optimal? Where is the best place to order a longer extension?
3) Where is the best placement of the two, (dual boda) antennas? Typically I have been told most all manufacturers recommend 90 degree angles on the antennas.
4) Am I correct with my understanding the satellite is an "antenna/telemetry satellite?
Any info./input/suggestions/hints on binding, setup and tweaking any of you can offer would be immensely appreciated.
Thanks in advance.....
Questions:
