I just double checked the compression ratio and the manual states 7.6 to one. This is very low when considering the use of a high octane fuel. I am not an engineer by any stretch of the imagination, but I do know that the higher octane fuels are formulated to not burn until a higher pressure, hence the use of high octane fuel in high compression engines. With this in mind, running the 100ll on this engine is probably not compressing the fuel enough to properly burn, especially when first starting it. The bog is more than likely more side effects of the lack of complete burning of the fuel once ignited.
I have a 3W-150 TOC, that I run 98 octane no lead, real gas in and it is a beast. The compression ratio on it is stated at 10.5 to one, which is providing plenty of pressure to heat the fuel before ignition for a clean burn. If I run 91 in the engine it will not run the way it does with the 98 I am assuming because the fuel may be starting to burn prior to the spark, thus giving me detonation, an engine killer if let run wild, and a lack of power. The engine runs quite a bit hotter with the 91 also. I assume I could back the timing down a degree or so and probably get away with running the 91, but as long as I have 98 reasonably close, I will just buy it 5 gallons at a time and run it
With that said, I also have a newer 3W-106, non TOC version that runs great on the 91 and provides no benefit at all running 98 in it. The compression ratio for this engine is stated at 10 to one. One major difference between the two engines, beside displacement, is I have a CH Ignition on the 150 and the standard 3W ignition on the 106. I noticed a big difference when I replaced the ignition on the 150 so I am thinking the timing curve is more aggressive on the CH ignition than the 3W one.
Ok, I will stop now. Hope this helps a bit.
