OK.
Got the tach info and everything else.
Here is the report.
Temperature: 30- 33 C
Pressure(hPa): 1009-1007 mb
Humidity: 14-11%
Hour of the day: 0900-1300
With the regular 29-13.5 I've got 6400-6500 rpm.
Very strong pool the engine is working awesome a little bit hot very agile and crisp.
Throttle management is a making the plane little bit jumpy on hovers and torque rolls.
Instant power.
Temperature measurements after the flight after 4 minutes freestyle 125 degrees.
With the new design prop.
I don't know what you did but it's even better. 6200-6300rpm.
All the benefits I've got with the regular prop are being kept but with extra mind to the engine hit...it run 10 degrees cooler then the regular 29-13.5.
After a 4 minutes freestyle temperature measured 115 degrees.
I use telemetry with the engine hit so it's a real time data all the time.
Throttle is smoother and more linear.
Less noise and no ripping at all !
It stays in the above 6000 rpm threshold we've talked about.
I then did a hover and some 3D and measured the engine at 129 degrees but it was a full 3.5 minutes of slow mo 3D stuff with a very long hover.
Pure awesomeness
