Ohio AV8TOR
Just Do It
Yes this is true but you do need to use an adapter cable instead of the standard powerboard cable as the plug at the charger is different.Yes you can use any paraboard. You will have to change the balance wiring settings as FMA's balance wiring is different than anyone else's.
