Tseres
Ohio AV8TOR;12427 wrote: Here is another good source to read. A much simpler manual I thought.
Thanks. There are some great explanations there.
Super08;12706 wrote: Tom once you get the hang of programming a Futaba the different transmitters they have are all pretty close to the same. It is just learning how they do things for the first time that makes it interesting, then it is easy. On my Carbon cub I will have flaps and ailerons set up with modes. In one mode only the outer ailerons will move with the joystick and the flaps will go up or down on a flap slider switch. In the next mode the flaps will move together with the ailerons as you move the joystick to give a faster roll rate. I may even add a crow mix later on for steep approaches.
Xpress;12821 wrote: I sat down with mine and just played with it for hours figuring out all of the features. It really is a VERY powerful transmitter, you just have to dig into its settings and you'll discover that.
Tseres;12913 wrote: Don't understand why they discontinued it.
DougV;12918 wrote: To bring in the 14SG with telemetry as the 8FG can't be upgraded for telemetry.
Doug
