Flatspinjim
You fly 2 sequences each round. 32 ounces should be plenty for 2 sequences, just use plenty of throttle control.About the only time you need full throttle is on uplines. It's easy to try and rush through the maneuvers but you'll find that if you slow everything down it will be much easier. Don't concentrate on each maneuver, concentrate on each line.
Oops, just remembered you'r not flying a 100 cc plane. You might need a bigger tank. Sorry
