Ain't that the truth. LOL. Love it.
Does that Byrne sander run in both directions.
What type of dowels are you using? Do you cope the joints or just sand to the correct angle?
Man you are going all out coping all the connection is a lot of work but it will make the connection solid. That is tedious work . But will look good when all done and then we cover it and nobody can see all the work you did.Spruce dowels, yes on coping. Kinda, trying to sand the cope with drill press and little sanding drum. I will not just butt joint the connections.
