That is correct, just showing what the 3 mm shears will do.Tony, the sides are already pinked, you are using the shears to cut the tape?
Pull-pull?I don't think a plastic Du-bro push rod is appropriate for a 40 lb airplane so looking for ideas. I might have a direct line to the servo but the flex of a plastic push rod is nice.
