I have a similar set up in the Champ. The box on the firewall houses the carb, the ignition is mounted on the bottom side of the box with Velcro and it is retained with a piece of hook and loom. The plug wires come out the two 7/8" holes. Access is through the door. Note the firewall is inverted in this photo. Is there an aluminum boot cowl on the plane covering this area? If so you can put a large hole in the filler piece without loosing much strength.
