Joe Hunt
Heat 'er up and Git Er Dun!
So, do you just cut it off flush? Or?
Cuffs should last about 20 flights so at least they will look good for a while I've tried them twice with no real success.
To install cuffs I slide them on, put a little piece of tape to mark on the gear where they go out to. Then clean the gear with alcohol and apply a LARGE bead of "Goop" on top and bottom. Apply it inside that tape by about 1/8". Slide the cuff up on there and tape the bottom and top in position. Leave the plane upright so gravity will keep the goop down in the bottom. Let dry overnight.
Never had one come off. If the top is a little floppy, use a syringe and put some goop up at the top as well.
The gear on Pilot 40% planes flex so bad they all have broke on me. I have them on smaller planes with no problem and install them on similar to Terry.
