@Jaketab I did not pin to the rails, just used weights to hold down while assembling. Two thing's of caution, use wax or parchment paper over the helling strips so as not to glue the wing to it. And make absolute the orientation of the ribs and the webs prior to starting, study the cd it does show them. I went as far as assembling with tape and weights, placed the wing tube in, double checked orientation and tube angle before starting the gluing process. The ribs with the tube cut-outs are very close in angle so just make sure. I also would highly recommend making a filet for the trailing edge sheet, it is very weak as is, solid balsa or some carbon fiber would do wonders. Also check the left and right plans for any difference in measurements and compensate prior to starting.Reference the above post, attached pic shows the stage of the wing build I am attempting.
Looking for steps 1 - 2 - 3 ect before proceeding.
Jaketab
You bet I'm clearing after all the vinyl is on. If anyone is attempting this build and don't have the experience then they need to research and study what is needed so to build on their ability. It definitely is not a beginners kit but it is not so far out there as to be too difficult for anyone with a little experience. Not jabbing at those such as Jaketab for asking question's, that is a smart thing to do. I found a couple threads on the German forums of this build which helped a good bit, as well as advice and tips from EMHW and Vogelsang.Get on it Ace !!!! Looks great r u clearing afterward ? Make a building panthlet with pics and info for us in English. M sure whom ever attacks this beast would purchse it ! Great looking paint job / got to Love them Pitts
