@Terryscustom, what is the distance between the uprights? Will it handle my 42% Edge with the gear on? I am not sure of the width off the top of my head. I do know it is a lot wider than my 35% Extra 330SC.
Just put mine together and I am curious what the largest plane you fit on here. This is huge. My 91" Extreme Flight Extra looks tiny on this stand. My outside wheel pants dimension is just under 23" leaving a lot of room. The wing tube only has 1-3/4" hanging out. Next run you make of these Terry will you work me out a price on a smaller base so I can bring the sides in.31" between the uprights. I had my 42% Extra on it as well as my hyperlite slick, works just fine. I suppose it depends if you are wider than 31" with wheel pants on..
