Problem starting new DLE111
Plus..it's very fiddly to fix. The recommended way makes it impossible to fit the cowl. So I had to flip it round.. and do a few mods on the motor mount to allow it to fit round the carb,
Also, the worm gear on the motor shaft wasn't great quality... not so much the gear as the small grub screw that was supposed to lock it to the shaft. I ended up tapping a bigger hole to accommodate a larger bolt. And using a Dremmel to flatten the side of the motor shaft to give it better grip.
