Scale Project Stearman
Alpha20
A buddy had one, the exact same yellow/red scheme with Moki 250. 4th or 5th flight he was doing a loop and the plane went straight down 90 degress towards the ground from about 100 meters high. He even had the time to show us there was no response from the elevator. We dug up the Moki from 40 cm under the ground. It turned out he had used an adjustable ball-link (the ones that you can tighten with a screw) on the elevator, and this came loose in flight. Both elevators shared one link. And the link itself was hidden under the vertical stab - not easy to inspect. Now he has built a new one, engine repaired, and with separate links for each elevator. In the air - the most beautiful model airplane i know of.
rodman
Bartman;13869 wrote: Linda's, as in Hobby Hut in NJ?
Yep Hobby Hut on Rt 23s Pomptonplains NJ They are personal friends of ours and are a great help to Cindy and I
during the summer we travel together going to events.
By the way it was nice to meet you in Hamburg PA at the Farview event.
rodman
I began finalizing the landing gear position making sure the alignment was correct.
then re drilled the mounting holes and installed T nuts.
Next I started drawing alinement lines on the engine fire wall.
I taped the fire wall to the motor box frame to check the alignment
Next i drilled the fire wall brackets and mounted them to the motor box frame rails with T nuts.
rodman
I aligned the fire wall drilled the holes and installed T nuts
and bolted it up to the frame.
I removed the fire wall and drilled the holes for the engine and hung it temporary on the airframe.
looks awesome to me lol.
Bartman
Defender of the Noob!
rodman;14379 wrote: Yep Hobby Hut on Rt 23s Pomptonplains NJ They are personal friends of ours and are a great help to Cindy and I
Ahhhhhh! Hamburg! I didn't put the Rodman name to the face. Firefly, A10, and Rodman.....gotcha.
Going back to Hamburg for the jet event? I'm going to be there I think if I get the days off from work. Nice Stearman project, love that engine!
rodman
Bartman;14517 wrote: Ahhhhhh! Hamburg! I didn't put the Rodman name to the face. Firefly, A10, and Rodman.....gotcha.
Not sure if we are going or not we have a few friends I'm sure will be there.
I have a Turbine waiver, but I don't have a Jet right now, Jets are a whole different pay scale lol.
maybe after the Stearman is complete I'll be able to save up for one.
rodman
I had to cut out some reliefs in the fire wall for clips and screws
that protrude from the engines mounting plate.
this will allow it to mount flush with the fire wall.
I wasn't all that happy with the design of the engines mounting ring
but there isn't much I can do about it.
