puked up a plug
crashflow
I have to find out if there is a difference between the v1 and the v2 heads . I don't know what version heads these are. I will call them in the morning.
ericb
Team WTFO
I have found a couple other stores that have it and they say V2-3, so maybe this is a V1 head. Hopefully.
ericb
Team WTFO
latest version which you can tell by the 3 round dots in the center of the cooling fins
crashflow
Big beautiful DLE 120 showed up today and is bolted up. I had to turn the carb around to put the throttle arm on the same side the dle111 was. Are the DLE plugs that came with it ok or do I need to get cm6 plugs? Ordered a 28/9wide for it. Such a nice motor for such a worn out airframe but anyway I should have it flyable again soon!!:yesss:
NGK CM6 is what I use. Less than 3 bucks from your local auto parts store. I toss the DLE plugs in my box for emergency purposes.
