jamesrxx951
I have seen many DA's raffled at many events. I have not won one though. And I have tried.
don't know....i was actually being a bit cheeky with that post. what happened to your Corvus?If thats the case Bart, then why is my Corvus dead. It had a DA 120 on it....
It was prolly the oil you run.[emoji12]DA 120 died in flight. Low powered climb out, around 1/3 power. 3 min into the flight. Usually when that motor would die. Sounded good on the ground, but load up when goes to take off. High end is spot on.
Definitely either the brand of oil, the ratio or the brand of radio you were using.It was prolly the oil you run.[emoji12]
I bet his servo fluid was lowDefinitely either the brand of oil, the ratio or the brand of radio you were using.![]()
