bbrown2828
So I have made a few phone calls today.. and I think we have our cause.. I talked to the guys at smart fly today.. and if a battery or a switch goes bad it will isolate that side. The diodes in the batt share will not let reverse current threw. He thinks one of two things happened, 1. I had ingition noise that came back threw my technical aero ibec. And locked me out. 2. I had over loaded my rx with amps... and after thinking about it.. The night before I had to move things around in the plane.. and had one of the servo city servo boards in the plane that feeds power to the servos from the board and puts no load on the rx..I took it out.. cause I really didn't have the room for it with out building more Trays In the plane. To mount stuff on.. cause I had to move a batt to its location.. so after this was removed.. I had 5 savox 1231 servos 1 ultra ibec for the ingition and a throttle servo.. All pulling threw.. The servo bus on the rx.. called Futaba and the rx is just rated for 8 continuous and 10 spike... so I think this might be our corporate. . Bad thing is I was only doing a loop... would be much more easier to say this caused it if I was in a KE spin or a blender...
