Terryscustom;5622 wrote: Last year I was at the same point and I never nailed it until I was able to adjust throttle while continuing to do the roller. Once you can do that it's all cake with a little timing and sounds like you are already half there. Once you cross the top you need to be able to cut out some throttle and increase the speed of your roller until you get to the bottom then increase throttle again and continue the roller. Like everything just practice. This isn't the greatest example because I was just messing around on a maiden flight but at about 2:40 a little rolling loopish kinda thing and you can hear the throttle chance and see how the plane maintains speed and momentum: https://www.youtube.com/watch?v=UYLP7gicXgs&list=UUmN3am68lG1nMdT8ujT6GyQ#t=149
This one shows doing it without the throttle change but but timing increases significantly: https://www.youtube.com/watch?v=UYLP7gicXgs&list=UUmN3am68lG1nMdT8ujT6GyQ#t=267
TazmanianDevil;5671 wrote: The timing with the throttle is crucial and you always go full throttle until you pass the 2 o'clock or 10 o'clock. Than you time it with the elevator and rudder so they will keep the plane lift it nose.
The throttle on that point doesn't go to idle but to 1/2 or 3/4.
When you get to the 3-4 o'clock point you than go full throttle again.
You finish it with full throttle cause at that point the plane is totally stalled
A good way to try it on the sim is by lowering the sim speed and practice the timing between the throttle and the ele and rudd.
In real it needs to be very fast.
Funny you say smaller plane, I tried for years with small planes because I was too chicken with my 40% er and never could nail them. When I sacked up and tried it with my big stuff, I nailed it first time. The small planes are just a little fast for me.TazmanianDevil;5691 wrote: Sim is the best way to know and understand these maneuvers.
By practicing it with sim, it will be much easier to do that in the air.
It's all about reflexes you'll need to teach them.
As for the chicken up top, just fly it higher than you use to.
If you've got a smaller plane try it with it.
