Ohio AV8TOR
Just Do It
So I use a 4" offset SWB arm for my rudder and as many they are threaded for the ball link screws. I am curious how you guys have the screw setup, do you just thread the screw with blue loctite to the servo arm or do you screw plus use a nylon lock nut on the back too? I have been using the nut too but is a PITA to install and remove with the screw threaded because you can't get easy access to the nut.
