Xpress
Since it seems like the discussion of lithium based batteries is always a topic of discussion, I figured I would bring some easy, simple how-to steps to help create a better environment for the care and handling of lithium batteries.
This is based off of my decade or so of dealing with lithium batteries so I will do my best to give clear and concise responses to any questions. Hopefully it'll help a newcomer to lithium batteries and further educate them on how to handle these magic bricks of fuse ignited magnesium flare based power.
First off, I want to discuss something that a lot of people overlook when handling their lithiums: SAFETY THIRD.
"What the hell man? Safety always comes FIRST!"
Well actually, no. No matter how many 'rules' or 'guidelines' there are out there, ultimately there is no replacement for good old fashioned common sense. Having common sense when handling your batteries not only makes your experience with lithium batteries much more enjoyable, but in turn makes you a much safer modeler. Common sense, in general, can make you that much better of a modeler anyways so it's best to start exercising that big organ in your head. Here are my basic tips on handling lithium batteries:
Do remember that lithium batteries will not just spontaneously combust. They are engineered and designed so that will not happen (even from China). There is always a reason a battery will vent or combust, though it rarely does happen.
For now, that is all. If you do have any more common sense tips then please do post them and I'll do my best to edit the topic appropriately. Don't be afraid to share your charging setups either, the more ideas and information there is available to newcomers the better.
Remember kids: Common sense always prevails.
- Do not cut both leads at the same time. Do not short both leads to each other. When soldering on new connectors, tape one lead out of the way and finish insulating the lead you are working with before working with the second lead.
- Charge the batteries out of the sun- heat is the enemy to any electrical component, and there should be no exception for your lithium batteries. Keep the charger out of the sun too.
- Charge in an area you can keep an eye on the charger and battery. If you feel so inclined, charge the battery inside of a brick or metal container.
- If you do have a battery ignite, smother it with sand. Do not disconnect the power leads until it is safe to do so, just work on controlling the flame. No amount of permanent damage to your body is worth saving your charger. Use a shovel to pick up the ignited battery and remove from the area.
