Gyro,
I was asking for clarification, not suggesting you were wrong
Joe I do understand. What I was thinking was on the CC I could set voltage where I wanted it and did not need to check. Obviously I was missing the point. I understand clearly now that the amps are going to go up as the servo begins to bind.
So now I have three questions. The first is how do I check current on the servos?
Second, I often find that as I break a new plane in, the control surfaces will loosen up after a bit of use. If, as in Wedoitall's case, I am getting high amps in the last little bit of throw, Should I back down, and then try again after 10 or fifteen flights?
I understand that I get better resolution with EPA at max. I also understand that I should use as short a servo arm as I can and still get proper max throw so that I can max out the EPA AND get maximum mechanical advantage. My question is, what happens if I have EPA at max and I use the dual rate to cut back the throw? Do I still get maximum resolution?
#1- There are multiple devices available that can be used to check the current draw of servos. If you are looking for a plug and play type device then I would recommend either of these. I have used both and they work great.
http://www.horizonhobby.com/products/digital-servo-and-receiver-current-meter-HAN172 (For one servo)
http://www.fromeco.org/Products/05FRCQCM/ (For multiple servos--40% wing with 3 servos for example. )
If you want a cheaper option, the you could use a simple multimeter and just make an adaptor.
#2- I do exactly what you suggested. I simply set the plane up with max epa and the throw I want. If there is some binding, then I will use the Dual rates to lower the throw until the binding goes away. I will then fly the plane for 10-20 flights and then go back and set the dual rate back to 100 and check the current draw again.
#3 Changing the dual rate in this case is identical to reducing the EPA. So even if your EPA is maxed out, and you reduce the dual rate to fix binding for example, it would be identical to reducing the EPA. A plane should be setup with the dual rate set to 100 and then only adjust the EPA.
