garlandk
Show your giant scale plane or iMac setup! About to setup a new iMac plane myself.
My plan is to run two Futaba 8 channel sbus rx with my 18mz splitting the airplane in half. I will be running the left ailerons and right elevator on one rx and right ailerons and left elevator servos on the other rx. Rudder I will probably split it in half.
Still undecided on my batteries. Running high voltage servos and plan on running two batteries plugging one into each rx. Plan on regulating the batteries to get a constant voltage.
Engine will be a DA200 with canisters and a three blade prop. Will also equip the plane with telemetry....engine temp for each cylinder, rpm, and batteries. Maybe Gps later down the road.
