IMAC FANATIC
40% happier than most folks.
Want to use T-1000 unit for rpm on DA 150, all spektrum has is unit for glo .90 and EP. Anybody modify the pick up unit to work CORRECTLY on a gas twin?
I have spektrum optical unit now but it has receiver type leads attached, can I cut these and simply splice onto telemetry end and plug to T-1000 with success ?
What are you guys doing and what parts will I need and how/where are you mounting them?
I'd like to use the open threaded hole on nose cone and use magnetic pick up from DA ignition. Or anyone have a way to get a signal from the ignition box itself?
RPM telemetry not necessary but would be nice to use for break in and prop changes.. If any.
And, using Spektrum DX 8 radio if that matters. Thanks guys.
