O
Ohio AV8TOR
What is your preferred method of balancing your spinners? I am not interested in what balancer you are using rather if you add weight, grind weight etc? I have used a Vess Balance ring on my DA60 and balanced prop spinner and bolt all at the same time. Results were good but it does not work for backup props you might take to the field or prop testing. So I am thinking of ensuring all bolts are equal weight and balancing the props and spinner separate. If adding weight to the light side what are you using CA, lead tape etc? Where do you add - on the back plate or inside to cone?
