Spinner Thoughts
I've used a Mejzlik before and It was very nice. I've never seen a No Limitz in person, but I know a lot of people like them.
With BLUE not red:mad:. I have a Falcon on my 104. Not cheap but not as much as a Mejzlik. I have and had Both.
jhelber08
Hover above your screen name and click on the privacy tab. Check the box that says allow people to start conversations with you...I just learned about this not too long ago as well.
camss69
I also have a Falcon spinner and really like it. First non-center bolt spinner I've had. I don't like the center bolt spinners because I've had the backplate crack from tightening them down too much. Then I don't tighten them down enough and the cone spins and makes a mark on the prop.. The side bolts I don't have any of that, just order some nylon washers and don't use loctite on the bolts and you're good to go!
