Starting DA-150
js-rc
Oh, ok Yakken !! I can try that too !! Oh, I think I have a nimha battery I can put directly to it & see.
Thanks for that, much appreciated !!
John !
Hello yakken or anyone !! I did that test just now with a 6volt nimha on the ign. without the plugs in & the left boot sparks in there. Is that where my problem is ? !! I hope that's it cause I can change the boot, I think !!
Also, with this 6volt battery & the plugs in the boots, the spark looked much brighter than when going through my SmartFly & their reg.
Thanks again, John !!
I have had trouble with regulators on my 150 it would start but not really run. Also with some small poly battery and regulars it would not run. Spoke to DA and they told me to run at least 1500 mAh battery nicad and try it the engine ran perfect all my problems went away. No regular for me on this engine.
js-rc
Oh, now that's good to know to !! I'm going to get the new boots put on then start testing it all again with different batteries when I get the ignition back.
Thanks snoopy1 !!
Pistolera
HEY!..GET OUTTA MY TREE!
I run a 2600mAh Li-Ion through a Sahara reg to drop it down to 6v.....going on 4th season now without a single hiccup.
js-rc
Thanks Earle !! Do you think because that one boot for the plug is sparking will cause the whole eng. not to start ? I'm trying to use the reg. that came with the SmartFly system & I think it regulates it down to under 6 volts but not sure.
Run all my other DA through a regulator that is made for ignition and works great for years but my 8 year old DA- 150 just will not and I have to run it on nicads. Do not really now why but it works.
sweetpea
Like most said.....
I'd try a full charged 6V battery with no reg. If it doesn't start after that........Send the whole thing to DA. They will fix it fast and simple and give you any updates.
I have an MPI reg on a DA ignition that is on a 3W motor (and those are cheapo regs) and mine works fine. SF are typically on the higher end, but it is always possible its bad....If you have a volt meter, run it inline from reg to ignition and see what volts its getting.
js-rc
I think my eng. may be just like yours, ha !! Though I haven't got it running yet.
Thanks, John !!
js-rc
Like most said.....
Thanks sweetpea !! I think I'm getting closer now as I'm sending the ign. to Milton to get both boots replaced . I do have a volt meter I can check that output voltage with & I will try to do that today !
js-rc
Like most said.....
Sweetpea, I just tested the voltage going to the ign. & it reads 4.02 volts !! I should be ok there , I think !!
Thanks again !!
