So Joe if I understand you correctly you don't use any subtrim or programming to achieve proper throws on an airplane of this size? Its all mechanical?
When you get to larger airframes is it the same process?
Is the above true for all control surfaces?
Thanks!
You are correct. I try to set it all up mechanically. I don't want to use the radio to cover up or fix anything. I can't stand seeing one endpoint at 140 and the other around 110 which is what happens if you set the arm to 90 degrees and use the radio to "fix" the incosistent throws.
This also holds true for setting up the elevator. Keep moving the horn on the spline until you get pretty close to equal throw in both directions of travel. If the rudder servo is setup in a push/pull configuration then this also holds true.
If you are setup to do pull/pull then here is some useful knowledge pertaining to that.
http://www.swbmfg.com/pages/Pull%2dPull-Wire-Explanation.html
I'll be back in a little while to explain the bigger planes.
