Naughty Monkey
Unless the geometry is correct you get binding. After a while I ended up just setting up proper geometry
This is the one time in my life since school that geometry was ever important. If you get the control horns set up right, it makes everything else so much easier. The pivot point of the control horns need to be in the same spot. They need to be the same distance from the hinge line, not the control surface and directly over the hinge line unless you want differential, then they need to be the exact same distance behind or forward of the hinge line. This keeps the throw equal throughout the full range of travel, not just the endpoints.
