stangflyer said
ericb said
stangflyer said
ericb said
The only thing I might have done differently is put the zip tie that goes through the arm on the rudder up through the bottom of the hole instead of down through the top of the hole.
Thanks.... I appreciate the comment. I can tell you right from the git go, it is already (from what I have noticed) so much more accurate and positive than any setup I have "FOUGHT" with. I tired it a little while ago with the weight of the stabs on and rolled the plane across the floor. As from before, It actually turned the direction of my rudder. OH HAPPY DAY..... YAY!
As for your suggestion? I thought about that.... I actually tried it both ways. Not that either is better or worse than the other....I just "liked" it the through the top. Guess you'd say I am a "top" kind of guy. Never really liked the bottom. LOL.....
Thank you Eric
I fought springs and other setups for years also. One night after another spring stretched to the point of no return I remembered seeing this setup somewhere and tried it. Might not be the prettiest, but it sure works. The best part is if it does break somehow, the components are available at any hobbyshop and cheap.
Well, I got a chance to find out if the new setup works as everyone says. YUP....it does. Might take a little finessing to get just the right tension...maybe just a smidgen tighter... but over all, it works. That at least I am happy about. Thanks to all that assisted with their ideas, opinions and input. I think it will stay that way, at least for now.
As for the Sukhoi, my springs from J&J Tailwheels arrived today. So, without futher adue, I got that set up as well. I am not going to double post so that setup will be over in the 3D The Planes category under the Hangar 9 3.1M Sukhoi thread. I am actually quite pleased with how it turned out. For once, the visions in my head turned out pretty much as I imagined.
Found out I had to tighten mine up a little also after initial tests.
