SteveT.
I thinks it's almost impossible to build a Steven's Aero kit without it coming out perfectly straight. The parts interlock and are designed so well that you can literally build them without glue, then just got back and hit everything with thin CA once you are sure that everything is perfect. There is very little sanding and they go together so fast that covering them takes the most time.
I would say that this is true of the few 3D kits that I know of. The SA Edge was actually designed (at least in part) by Scott Stoops of 3DHS designer fame. All of his 3DHS Edge designs came after that, so of course they were improved. The SA Edge airframe is still ridiculously light even by modern standards (not many 3D planes this size fly on a 3s 2100!), and it flys really well. The newer designs do fly better though.
My SA Edge just had the components removed after several years, and were put into a 3DHS Yak 55...
View attachment 1389 View attachment 1390
You did a very nice job on that plane Greg!! Great covering and painting job!!
SteveT
