Dang it! That sucks most profusely my friend. But it truly is how you look at it. From your description of events, it could have ended most unsatisfyingly bad. I'm pretty sure however that planting balsa in the same field that beans is growing is certainly not allowable. Not supposed to mix and match. Remember, you must rotate your crops.Well it was a nice day at the field today, but unfortunately it ended up with my 105" Extra upside down in a bean field.
On my second flight, the carbon fiber spinner cone decided to part company with the airplane and go through the prop and hit the cowl. I killed it right away since I wasn't sure if the prop was still in one piece. Unfortunately without the prop turning the plane doesn't slow down and I barely touched down before I was out of runway. I ended up in the bean field at the end of the runway and it nosed over at the last second.
I like to bad mouth this Hangar 9 airplane for being an over weight pig, but the balsa sheeted foam core rudder doesn't have a ding in it after flipping over. A built up one would be in rough shape. The cowl is cracked in several places, the landing gear is tweaked, the wheel pants are beat and the props done for. But considering what could have happened if the prop came apart, and one blade is pretty bad, I consider myself lucky, It could have been much worse.
Sorry for the bad pictures, but the lighting in my family room isn't great for photos.
View attachment 104209 View attachment 104210 View attachment 104211 View attachment 104212
Yeah I've seen what happens when half a prop comes off and it's REALLY ugly.Dang it! That sucks most profusely my friend. But it truly is how you look at it. From your description of events, it could have ended most unsatisfyingly bad. I'm pretty sure however that planting balsa in the same field that beans is growing is certainly not allowable. Not supposed to mix and match. Remember, you must rotate your crops.
Removing the landing gear is the part of the fix I dread the most. The cuffs are glued to the fuse with clear adhesive silicone and that stuffs a pain to get off."Really Ugly" sums that scenario up pretty well. So glad you still have an airframe and that DA120 is more than likely unharmed.
Of course this just "had" to happen after you perked up the LG, wheels and pants.
Cool little foamie.Huck'd the GB Indoor Extra 330SC last night. Always a joy flying these little flat foamies.
