Tomcats3DRC
This maneuver is a combination of doing a rolling harrier and a corkscrew. The throttle used varies on which plane you use but on most it's 100%. You enter it by gaining altitude and pointing the nose straight down. You start rolling as soon as the nose is pointing down, then you start doing rolling harriers in a circle. You try to keep the nose at a 145 degree angle towards the ground as the plane is rotating around the center point in the shape of a corkscrew. In this video at 20 seconds I demonstrate the rolling corkscrew:
https://www.youtube.com/watch?v=mykEh2_t9Vs
If this doesn't work, you can also find the video at wcolby1's youtube channel under Precision Aerobatics Katana MX.
I used the Precision Aerobatics Katana MX for this video.
