3dNater
ive slowed down the physics also, have worked my way up. on my TH foamy i just started getting the throttle pump down, but i cant keep a straight line. most of the time i can do rolling harrier circles for an entire length of a battery, unless i cut the circle to sharp about 270 degrees into the circle, which happens sometimes, then i have to reset.
Ok so it is a matter of practicing in a straight line and learning to react to the attitudes the plane is in. You are going to have to deliberately wait longer for each input. You know your problem is being early and knowing is half the battle... now its just practice
By the way if you are doing good rolling circles it sounds like you are making rapid progress!
