Mikeq
I use Sullivan Gold–N–Rod...blue outer sheath with a gold nylon inner rod... 2-56 threaded studs and 2 locking ball connectors... I do disconnect the spring from throttle lever... This way if something happens and the servo tries to push past the stopping point it will bend the rod before binding the servo... hasn't happened yet but if it does I won't have to worry about burning up the throttle servo..Oh I use a Futaba S9070HV metal gear servo and an IBEC to remotely kill the engine if need be... Just today had a club member take off only to discover his metal throttle linkage had slipped past the set screw that was holding it in place and no throttle wound up being 1/4 throttle..needless to say he flew around for 15 minutes burning up fuel before he could dead stick in...
