Throttle weirdness
Glad you found the issue! I run an RX batt in all plane 70in larger. I've had 1 too many BEC failures and a plane that size can handle the extra weight.
+1
If you do run a BEC on a plane with a series connection, there's nothing gained by not using the low side battery to drop the voltage into the BEC.
