I'm not sure I get it. Do you mean some way to kill ignition power other than with the IBEC? Isn't that the purpose of the control signal from the rx to the IBEC?Like others say, if it ain't broke, then why fix it. You just need some way to kill power to the ignition. It doesn't matter how you do it. Servo and micro switch is how alot of folks do it.
Never, I've probably bought two dozen of them over the last few years. Not one problem on any 20-120cc engine.
Sorry, in a short rush there........ Provided you are running an ignition pack, is when you need some sort of kill switch. But if not running an ignition pack, then none of what I said is needed. Using ibec, rcexl works great! Ive been using rcexl for a couple years without issue.I'm not sure I get it. Do you mean some way to kill ignition power other than with the IBEC? Isn't that the purpose of the control signal from the rx to the IBEC?
Still trying to work thru the android mobile and tablet issues. Need a bit more time to check into the fix..![]()
Yup, couple of 'em!! I think I've had just about everything 20, 26, 30, 35, 40, 40 twin, 50, 52, 55 , 60, 60 twin, 61, 70 twin, 100, 111, 120, 150, 170, 176.
Oh I "DO" like that one.
